TS2 PROBLEMS
HI..CAN ANYONE PLEASE HELP ME...I GOT MY TS2 OUT TODAY AND IT RAN GREAT AT TOP END...I AM HAVING A PROBLEM WITH THE BOAT PORPISING ON THE CORNERS AND WHEN SLOWING DOWN...I HAVE CHANGED SEVERAL ENGINE HEIGHTS AND HAVE A NEUTRUEL PROP ANGLE...WHETHER I LIFT ENGINE,DROP IT CHANGE TRIM,ADD WEIGHTS NOTHING SEEMS TO HELP ON THIS HULL..IS THIS ENGINE OFF SET AS THE MEASUREMENTS ARE DIFFERENT FROM THE SPONSONS....THANX
My experience running a TT on the TS2 hs been rather disappointing compared to the O.S. or K&B. In stock configuration, the TT doesn't develop the RPMs of the other engines. It is also much heavier. One thing you might want to try is increasing the negative prop thrust and raising the prop. Be sure you have the forward recovery pads glued to the underside of the tunnel when making this adjustment.
Another thing to try would be to make sure the balance point -10"-from the back of the boat is correct. It might take some amount of lead placed inside the cowling and in the lead slot to achieve this balance point w/TT engine.
JD
JD
hi jerry...ok I have decided to change the TT ENGINE and put my tuned pipe KB onto it and my luck the TS2 is still porpising at low speeds and turning...Jerry are these hulls known for this problem as I have done all sorts of testing with props,engine heights,engine angles,weights is all different parts of the boat so really lost now...thanx for your help mate
barry
barry
ORIGINAL: winzracing
barry
barry
Bouncing at low speeds is pretty common. Try a smaller prop with your K&B - X438 would be a possible choice.
JD
