newbie needs help
newbie needs help
having trouble with my boat. this is my first one ive ever owned... i can get the boat started but when i put it in the water it just shuts right off ummm not really sure whats going on tried to get it to work all weekend and suggestions will help
thanx dave
thanx dave
RE: newbie needs help
its a inboard engine havnt touched the screw on the carb just the fuel one not sure on engine size but ita a water cooled tiger shark its an asp engine if that helps
Richen it some more. You are reporting all of the symptoms of a lean mixture - Runs fine on the beach and quits when you put it in the water. You can't tune a marine engine on the beach. It's a trial and error thing on the water. If you blip the throttle on the beach and it accelerates smoothly then it's to lean for the water. It should hesitate and sputter when you blip the throttle. Then it's ready to fine tune on the water. Whatever you do DO NOT run the engine on the beach at high RPM. We've been through that story before on this forum.
