TS2 PROB
FL
TS2 PROB
Trying to get my kids Christmas present set-up so he can run it on Christmas am. Its a ts 2 w/ os 21 xm. The motor is broken-in. Runs great until you throw it in then it runs ~ 15 mph. Barely gets sliding. Have tried 3 different props with the same outcome. Runs great and winds up like you would expect on the bench but as soon as its splashed it bogs. Any thoughts? Thanks.
RE: TS2 PROB
Place the boat on the setup board side of the boat stand and make sure the centerline of the prop is at least 3/16" above the board. The O.S. loves nitro - 40% - 60% will work fine.
JD
JD
FL
RE: TS2 PROB
Thanks. Y'all were right. I set the heighth correctly, but didn't tighten the bolts enough and it slid down. Runs fine now. Alittle slower than expected but I'm only using 20% and slightly rich adjustment because it is my 7 yr olds boat. Also, somewhat tricky to find the fine line line between adding weight and prop angle. Have 3 oz in the bow and trimmed up 4 or 5 degrees to get it to ride right. Thanks again.+
RE: TS2 PROB
If you have not done so, glue the front recovery pads to the inside of the sponsons. Getting a tunnel boat trimmed does take some effort. 20% fuel is definitely a "mild blend."
JD
JD
