Hydro Build Challenge : Dan S .18 FireFighter
NB, CANADA
All I have at this time are the Plans for the FF 18.
I am having difficulties getting the proper wood for the build in my area, if nothing turns up I will have to order online.
Once I have something started I will post some pics.
Dan.
Dan.
IL
RE: Hydro Build Challenge : Dan S .18 FireFighter
good quality wood from http://www.osbornmodelkits.com/ in canada
NB, CANADA
Thanks Tom,
thats the link I was looking for, so far I have been out of luck in my area but I still have a few places to check.
IL
Hi Dan,
Just wanted to post this info for you. As of 01/05/08 your "FREE" OS CVR-M .18 is in the mail, I also included a header and some delrin in case you want to make a engine mount similar to the ones I have been using. The engine also has a flywheel and a flex hex coupler, I hope everything works for your build
Paul
p.s. I also included a 1hr DVD for you ...............................
Paul
Dan, I don't know what you need for you rigger build but carl use to have a lot of thin plywood and the like.
I believe they call it "aircraft ply".
good luck
NB, CANADA
Thanks Paul..........I'm starting to be like you at getting stuff.
Thanks Ron.
Thanks Terry, will check with Carl.
Dan.
Thanks Ron.
Dan.
NB, CANADA
Ok,
Since I don't have the wood yet, I decided I might as well start somewhere.
Soooooo....I printed out the first set of plans (main plan) and proceeded with the cutting, matching and taping.
The end result:
Dan.
The end result:
Dan.
IL
Hi Dan,
I had read somewhere that you where questioning flex shaft size. On the .12 I am using a .125 shaft that has a stepped prop shaft to .187, I would guess you should use a .150 flex stepped to a .187 prop shaft . I would also recommend you go with atleast speedmaster hardware for a 20 hydro, prob a mini rudder. On the .12 I have I am using CF arrows I got from the sporting goods store, they gave them too me ( I guess some stores actually calibrate the nicer bows and if the feathers get messed up they throw them away , you could ask)
Paul
p.s. These places sell stepped flex shafts but the Hughey are a little different not sure if ya need Hughey hardware.
http://www.drcwebservices.com/ffe/hardware.htm
this is octura: http://www.offshoreelectrics.com/pro...oct-oc150L-24c
Paul
NB, CANADA
OK,
I know its been a while, parts are coming in slowly, wood and foam is on its way (on order).
have engine mount, motor cleaned up, replaced conrod and ready to go. CF spar ready to be cut, main template to finish and waiting for my Scroll Saw.
Dan.
Dan.
NB, CANADA
OK,
I have almost everything and will be able to start soon.
mean while since my oldest Son moved out, I have been working on his old room to make it MY little workshop.
this is the results:
Dan
Dan
NB, CANADA
Martin,
That was my initial plan, but I was able to acquire the laser cut kit.
There are 6 pieces missing but thats no big deal, I will make them.
Dan
Dan
oh cool, its a great boat i love mine..the reason i asked is im building an ff12,but i have narrowed it up and i dont have the top and bottom for it.. im not sure where to get the wood or make a nice job of cutting it out like the laser cut stuff.
The wood is usually easy to get as most hobby shops should carry it.
We've cut a few kits on my sisters laser cutters, fun little toys to have if you can afford them but 20 Grand a pop is just a little out of my price range.
I made Tom an offer for her to cut his kits but he didn't take her up on it otherwise we'd have spare parts galore.
IL
Hey Dan, Well I see where the last proto went now. I had 3 protos cut. They were the last boats my old laser cutter made for me. Well i'm glad to see your showing your build. I really need to make a photo gallery on my firefighterboats.com web site! What parts were missing. I know the sponson outsides.... not a precision part.
I'm working with a new laser cutter now. That is a big reason for the cheese12 design. the new cutter has only 24".... that dang ff18 is like 24.7" tub!
Good luck! I hope i'm not the last one done! Honestly i've been working on my gas rigger the most lately.
NB, CANADA
Going a bit slow but its going.
I bought a sheet of 1/32 and a sheet of 1/16 ply, the inside piece for the front sponsons are done and the outside skin for front and rear sponsons are done also.
All the foam has been cut, and 50% Epoxied.
worked on the spar and part of the sponson.
The foam (Blue) is 3/4".
IL
Hi Dan,
Looks great, I hope that foam you are using isn't to thick? You don't want the measurement from the inside skin to the center skin to be over 1" . If it is it will interfere with the forming of the outside like i showed you in the pictures in my build. But geez you are almost past me now in the build
Paul
When you set your top on and your back piece on you don't want to be able to see the 1/16" ply center at the top right corner or the bottom right corner.
Paul
NB, CANADA
OK,
A bit more progress, outside skin glued to foam, plans called for 1" of foam so I used two 1/2" pieces (rear sponson).
Front sponson all Epoxied, The inside and center skin and the bottom skin of sponson epoxied. the blue foam is 3/4" and the pink foam are three 1/2" pieces to make 1 1/2" thickness as per the plan.
Dan
Dan
NB, CANADA
Now have 99% of Front Sponson completed, foam has been shaped and they are ready to receive the final skin.
To tell you the truth at first when I was looking at the sponsons before they were all put together I couldn't figure out how the Heck I was gonna fit that outside skin?????
Once its all together you can see the picture and its actually quite simple.
Oh! and note to self "when using X-Acto knife ensure fingers are out of the way"
Dan
Dan
