drivehelp please
drivehelp please
Hi i have converted my koysho jet stream ep 800 to nitro
i have had that many problems took me years to do
now problem i have it has a universal drive sp the prop moves when you steer
great in electric as you can power down but as its nitro i try to turn the boat jumps out the water and turns slows it down a good bit
now im going to take off the universal drive but thinking of keeping the rudder on the hull as it is now with the prop shaft going thro it but with a rudder behind it or do i have the rudder to the left hand side
the original rudder will be fixed so the boat will be more stable or do i take it off as it a very small rudder the universal drive turns the boat so i keep the prop the same distance away from the hull
im running a force 21 in it tried a 61 but it was way too big i would not fit inside the hull lol i look forward to your help kind regards stewart
RE: drivehelp please
First I would pull all that plastic hardware off and find the nearest trash can,, It looks like vegas hardware could be adapted to that hull pretty easy and the best part it would be adjustible, is that a piece of hose I see hanging out the bottom? Along with the hardware you may have to change out the flex shaft and tube and add some trim tabs on the stern.
thank you for your thoughts
going to keep the universal joint but have the rudder solid and place another rudder behind it to steer it see if i can get away with not taken the rudder off boat will run very straight hopefully it will turn or be very messy lol give that a go this week as soon as i get time as got to fix my air boat too and im learning to fly too many hobbies not enough time lol
thank you for your ideas im now going to take off the plastic rudder !
now i keep the propeller at the same place
do i put a rudder behind it then or at the left side if you looking at the front of the boat or the right from the back ?
i go and hassle my mate use his garage tonight try get it done going to use aluminum keep the weight down as it is very heavy at the mo at the back got a metal prop give that try
better start it i try post pictures later on
