.18 tuned pipe
OH
RE: .18 tuned pipe
yep...you need a 3.5 tune pipe for your.21 I'd tried that three years ago .Try a.18 tune pipe on a.21 and it did hit the pipe/boost didnt kick in.[>:]
RE: .18 tuned pipe
ORIGINAL: Dan S
before I say yes or no,
what pipe are we talking about?
Dan.
Dan.
Let's say that it's a Cooper .15-.18 pipe just for one to talk about. That one is basically what was once known as an Irwin .21 short pipe. Cooper took over Jim Irwin's inboard pipe business while he kept the OB part going. The 21-S pipe was a rare one that worked fantastically on everything from a .12 to a .21. Rod Geraghty found that out while trying to find a hot pipe for an "A" hydro record setting boat.
Now if you're talking about which I am presuming that you are, then it can be a toss-up. It can also depend on what engine that you want to use it with.
There's only one way to find out but set the pipe up so that you can adjust it through a good range of lengths.
MI
RE: .18 tuned pipe
Not sure of the brand, A friend of mine has it and he said it came off a a .18 The motor is a k&b 3.5 inboard ( i still can't find a black carb for). The pipe is 8 1/2 long and 1 1/4 at widest point.
