Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
servo
Old 06-22-2009 | 08:42 PM
Default servo
Would like to know what size and torque servo you guys are using for steering on your sport 40 s??? </p>
Old 06-22-2009 | 10:43 PM
Ron Olson's Avatar
Default RE: servo
Hi-tec HS 645MG or higher.
Old 06-23-2009 | 12:00 AM
Default RE: servo
Thanx Ron How much torque and does metal gears make a difference??????
Old 06-23-2009 | 01:20 AM
Ron Olson's Avatar
Default RE: servo
I couldn't tell you off-hand what the numbers are. I've used the 645 in everything from .21 mono's up to my gas boats including the Sport 40 that I had.
You can check the spec's of all Hi-tec servos at www.hitecrcd.com .
Metal gears are less prone to breakage. Pull the cover off any servo, especially one with plastic gears and see how fine the teeth are and why you'd want metal ones in there.
Old 06-23-2009 | 07:12 AM
Dan S's Avatar
Default RE: servo
the HS-645MG have 133oz/in at 6volts (5cell pack).
Dan.
Old 06-23-2009 | 08:59 PM
Default RE: servo
thnx guys Now I know the servo I was planning to use does not have enough torque. Planning to use a jr z590 it has metal gears but only has 82 oz of torque.
