will it work (Engine)
Hi im Newcomer in the Rc world so..
I just bought a boat that is 1.20 meter long / 3.9 feet long and weight around 4.4 Kg / 9.7pound now to my question
Im in need of a engine so.. will some of these engines be strong enough to reach speeds around 30 knots or 34.5 mph and above,
and may not cost more than 150 dollar +10 dollar is okey. please respond and take your time im in no hurry
u may post a link to some other page
http://www.rcmart.com/catalog/engine...=3a&page=1
lots of thanks to u how respond
ON, CANADA
those engines are designed for cars and trucks as a newcomer i would look for an engine designed for marine use O.S .46vx-m would work but alittle out of your price rang at $250 .00 us not shure what that converts to dynamite .32 cost around $120.00 to $150.00 us but may come up a bit short on your 35 mph goal then there is e bay k&b 7.5 if you can find a good one hope somwe of therse get you started in the right direction
TX
I would think, if his budget could handle the $250 price you mentioned, that his best bet would be a weedeater engine (ZEN). Might even be able to find a used one that is in his budget, or close...
Sean
Sean
TX
Hi KioskMongot!
Welcome to the Hobby.....
Is your boat a hydroplane, or a mono hull? I would imagine a boat that size without looking at it, would take a 11cc or .65-67 engine or one of the Zenoah "weedwacker"gasoline engines...However you may have to pay more unless you shop online at ebay for example...
Heres a web site you may want to check out...www.mecoa.com
thanks for quick answers well my boat is a mono hull and i have looked on the web for bigger engines but cant find any. not bigger then those on Rcmart and towerhobbies and such big sites. and to be honest im not a complete noob in this cuz when i bought the boat it had an engine but a very old one and i probably got fooled when i bought it because the water cooling that held down the piston cracked so and i not sure what cc it had but i think around 5-7 cc... if you know any more good good stores please post a LINK and they have to ship to Sweden. i sound very demanding now... ^^
Im just going to shred water
ON, CANADA
post pics of what you have someone here wil know what it is and where to get parts and we will also get a better idea of what you want and need
The hull is homemade i think so that will be quite difficult but i cant hurt so hers some pics
http://img109.imageshack.us/gal.php?g=batgd.jpg
I have also looked on eBay and found this engine should be enough in my opinion
last one has a clutch and that is a plus i think
http://cgi.ebay.com/27cc-4-25-HP-CY-...item35a4c406cc
AND
http://cgi.ebay.com/26cc-gas-marine-...item414a74ea4a
AND
KioskMongot - your hull with the Sikk installed and properly setup should exceed your expectation. if your going the Gas engine route stick with Zenoah,RCMK or the CY/Sikk as spares are easy to get. Just remember you'l still need to get a pipe & header.
