Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Throttle set up on a out board
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 11-24-2009, 01:28 PM
zen3
zen3's Avatar
Default Throttle set up on a out board
I have a tunnel hull with a os outboard. I'm trying to set up the throttle. When the boat runs left it puts strain in the throttle servo and pulls so stearing is slow. When I turn right the slack pushes and the motor slows down. How are the outboards set up not to do this. It's very fustrating.
Old 11-24-2009, 03:32 PM
rcguy1411
Default RE: Throttle set up on a out board
you need to make a cable holder that clamps the cable so it dosent change lenght i made mine out of a pice of brass i had and a bice of fuel tubing atached to the yop of the crankcase this has worked great for me on the K&B 7.5 should also be good ob the os you have
ID:	1319841   Click image for larger version
ID:	1319842   Click image for larger version
ID:	1319843   Click image for larger version
Old 11-24-2009, 07:30 PM
Tombsy
Tombsy's Avatar
I replied to your thread on RCG but the OS should have a black plastic clamp to secure the cable cover. A little crazy glue helps stop it from slipping.
Old 11-27-2009, 02:10 PM
racejunkie538
racejunkie538's Avatar
Hi
Make sure you have enough lenght on your throttlecable for steering, lay down the cable in some small S shape inside your hull.
All OS outboards have a cable holder, you will need this. I have thicked up the end off the cable with a pice off pipe
so it will fit tight in the cable holder. (fix it with CA or 5min epoxy) For throttle cable I have used the "Sullivan Gold-N-Cable"
Good luck
rgrds Marc
ID:	1321565   Click image for larger version
