rigger building
rigger building
does anyone have pics of a jig that i could make so i can make my riggers also could i use fiberglass resin instead of epoxy if not what epoxy should i get and where
RE: rigger building
I dont have my jig here so no pics now, but it is very simple. I used 1-1/2 by 1-1/2 alum. angle just use it like they do the ruler. I did locate the boom holes in mine but you dont have to. one thing that will make things go alittle better is to put your motor mounts and front boom holders to gether on a piece of 1/4 round stock (metal) glue and sand then your holes will by nice and straight. I have done six of them for guys around here my jig holds two and Ill get some pics if you want but theres nothin to it lay the angle down and clamp the sides to it.
RE: rigger building
I use epoxy to put it together and two coats of resin, very thin coats and for a final sanding I use a razor blade so I dont dull the egdges
Any good hobby epoxy I like 30 min and on the resin I use evercoat. west is great but its hard for me to get
RE: rigger building
I'd wait for Joe to come out with the gas kit. There are differences between the .12, .21 and .45 kits already and the gas version is now in the testing stages so I don't think that by just blowing up the .12 kit is going to do any good.
The JAE .12 doesn't need a jig, my 2 turned out nice and square without one. No problems with the .21 either.
MB, try boat dealers for West Systems. If not, cruise up to the Toledo show in April, somebody will be selling it.
RE: rigger building
I chose to use 2 bar stock alum,for my jig. I can see the bottom & side during setting up on the 30 min epoxy. Add some weight on top for setup. Here are some old school build ideals. The alum bar stock is 3/8"x3/4"x6' from my local ACE hardware.
RE: rigger building
You can get west system epoxy from west marine online or you may have one close by, I live only 5 miles from a west marine on the stockton delta, they have many types to choose from but the web site is very helpfull with that.
RE: rigger building
Ron What was that about a hull repair? I think those blocks rolled during setup. Gotta Laugh I almost had 2 right hand sponsons, hole in each end, see what I mean.
RE: rigger building
Ya know those itty-bitty front sponson blocks? I had them held in place with a clamp with they were drying. Well........., some of the glue leaked out from between them onto the clamp. The wood cracked a little right at the front bulkhead. I also had the foam already installed so I had to slit that down the middle to get it straight again.
It wasn't a hard fix and you can't even tell that I had messed it up a little.
RE: rigger building
Yes it's the little things that get ya! zippkitrunner You need a tall ship to build,Now that's a build. We still got alot of winter up here. Another rigger maybe I got alot of ply around here scratch build KEP'S .21 .The ZIPPKIT is a breeze. lots of fun, will be watching your build
RE: rigger building
i just primed it you guys are right i need a challenge. i think im gonna build an 8ft deep vee scarab hull and put some crazy power in it and make it all out of homemade stuff . i built a 6 footer over the summer with a stihl engine and it only took 20 minutes and some guy offered me 500 for it SOLD i made it from junk ihad around and it only did 40mph . well lets see what happens
RE: rigger building
ORIGINAL: zippkitrunner
if this kit gets any easier i will be bored again
