Central NEW YORK boaters
#3676
NY
RE: Central NEW YORK boaters
I'm getting used to saying Great Job Toast Joe will have his chest pumped out showing them hulls off.
I started my 45 twin build, I want to change the nose. Just me [8D]
#3679
ORIGINAL: Hesco Racing
Now why you go and paint the boat looked good in wood cleared finish.
Cobus
Cobus
#3680
NY
I started to work on my 45 twin Zippkits rigger build. I can do my brass driveline and radio box layout. I also have the 45 Zip to seal and paint. Painting the sponson's and top of the tub. everything else clear.
Pigment will add weight. I want to be able to see the hull during a race. At them speeds any dead boat can be damaged easy. Speed kills
#3683
ORIGINAL: advanced builder
What dia brass do you have in the twin? that should be done before the ski is attached.
Mr. toaster
#3684
Thanks Toaster!
Awesome craftmanship on these boats for sure.
Neil, the 45 twin does not get any brass tubes in the tub. The brass and aluminum will form a permanent bond, unless you remove the boom tubes after every run...
Just a tiny bit of silicone around the front tube to help seal it to the tub, but still be removable if needed.
We like and use boom tube collars, even on the 67 and gas boats...
Joe
Joe
#3686
NY
Yes Roger the dia of the stuffing tube. the 1/4 " seems small. I do have 5/16 or 3/8 bras pipe. The single 45 build has hardwood under the boom tube. So I am able to remove the boon tubes No clamps Screwing the boom tubes to the hull.
I knew they were to display ,So no drive-lines for display.
I'm in no hurry to finish the 45 twin. I do not plan on racing the twin hull. Just thinking out loud.
And to keep my tread going Here
#3687
#3689
NY
Here is my 45 JAE rigger with a new cowl https://picasaweb.google.com/lh/phot...eat=directlink
From 2-15-2013 |
#3692
From 2-15-2013 |
For a long time and you exchange
,Your DF-45 boat finished ?
I just completed a new'JAE-21 ~ Charcoal-Broiled lobster ~
I have I asked you 'JAE'-21 will be a what speed?
H-7 propeller best ? There are any good recommendations ??
CKY
#3693
ORIGINAL: c.k.y.
Hi Neil
I just completed a new 'JAE-21 ~ Charcoal-Broiled lobster ~[img][/img]
CKY
[img][/img] |
From 2-15-2013 |
CKY
#3694
Here is where we are at with our larger driver stand and CD station. The CD station will be completely enclosed from the weather and measures 8 feet x 10 feet. There will be a length of 24 feet for the drivers.
#3696
NY
ORIGINAL: c.k.y.
Hi Neil
CKY
[img][/img] |
From 2-15-2013 |
CKY
#3697
NY
we found that the lower the strut ,the better. Look were the wood ski stops ,at the front of the strut. My stuffing tube is resting on my ski .Your prop will grab more water.
#3699
NY
ORIGINAL: Blackout
Neil, Is that a VAC 45 under that cowl? I'm in trouble if it is.... CMB vs. NR....
cky your strut should be OK as you have a long strut. It's back plenty.
Work crew will be @Stony Pond in 2 weeks. setting up a fence for the season.
#3700
My ski and strut only 1.5m.m. distance ( because I get rid of the bottom of the strut )
I have some 20 years ago, wood 3.5c.c.Hydro photo[/i]... It would be " JAE " predecessor here > > > Ha.ha
CKY
