propeller selection
propeller selection
hey! i currently have a pro boat miss llumar hydroplane. The propeller that is used on it right now is octura y534. I was just wondering is there another alternative propeller that i can use that is not plasctic. Thanks
FL
RE: propeller selection
The Octura Y535 is the standard Metal Replacement for that boat, if you have the .18 the Octura M435\3 (3 blade prop) will work very well also. Make sure you get it Balanced, Sharpened, & Polished, or Do It yourself, a Raw metal prop will perform Very Poorly and destroy your prop shaft and strut.
