K&B fuel needle setting!
WA
RE: K&B fuel needle setting!
Check out this thread, same problem as your having.http://www.rcuniverse.com/forum/m_9059210/tm.htm
3 1/2 to 4 turns out on the older K&B black carbs. Seen where a SS needed to be 4 1/2 turns out. K&B needles are not perfect. That is why I use a flow meter to determine the best setting for the motor. I've seen where turning the needle out, it leaned up.
