TS 2 FUEL TANK
Hi, Anyone have a good idea on the best way to fasten the fuel tank on a TS2. They send you that hook and loop stuff but that dosent work very well. Thanks[:o]
RE: TS 2 FUEL TANK
ORIGINAL: wakemaker Hi, Anyone have a good idea on the best way to fasten the fuel tank on a TS2. They send you that hook and loop stuff but that dosent work very well. Thanks[:o] JD |
RE: TS 2 FUEL TANK
Make some new mounts and screw it down?
RE: TS 2 FUEL TANK
i used velcro or double sided tape...
RE: TS 2 FUEL TANK
I normallynuse silicon as it also cushions the tank from vibration, preventing foaming of fuel. First roughen the two surfaces up with sandpaper.
RE: TS 2 FUEL TANK
I used what came with the boat and it worked fine for an entire season. Remember, the cowl also holds the tank in place.
RE: TS 2 FUEL TANK
If you use Velcro, you can CA it to the hull and use a Shoe-Goo type of silicone on the tank to hold the Velcro on it. This works well if you use a softer tank like the Sullivan's that flex more.
