Proboat hydro
Hi I got a Formula hydro from proboat are there any tricks that I should do I just ran it for the first time seemed ok but I hit a pile of weeds and broke the prop. it has the .18 motor so is there a good prop that would be a direct replacment for the orignal one. I did read on here about them taking on alot of water. I bought fuel line clamps but the fuel tank leaks is there anything else I can do or upgrade. Also what would be a good radio to run in this boat.
Thanks Dave |
RE: Proboat hydro
You need to read the Miss Bud post it has alot of info on them!! It's the same boat as the miss bud!! You need to get a y535 metal prop for it. To keep the water out,you need to get weather gasket material to put around inside of the cowl lid. Two you need to drill a hole in your motor compartment on the left hand side back corner,were the motor compartment and radio box meet at/at corner.So the water can drain out of the motor compartment.I had to rebuild mine wood in the motor compartment because there was no water hole to drain the motor compartment out.I have three Miss Buds,Two flex drives and one strait shaft one. I'll find the bud post is at and post here for you so you can read it.Tons of info for you!!:D:DHere it is.Plus heres the video of my boat with the vegas.18 in my miss bud.[link]http://www.youtube.com/watch?v=18MZZWSB11M[/link][link]http://www.rcuniverse.com/forum/m_2799689/tm.htm[/link]
RE: Proboat hydro
thanks Miss hydro it looks like I will have to do alot of reading. That prop has to be balanced and sharpened but I would just rather get one done allready if that is possible. one more thing is that prop a direct bolt on?
thanks Dave |
RE: Proboat hydro
Yes they are!! You can also get them from aquacraftmodel.com.there almost balanced and there polished too.Some guys are just putting the aquacraft one directly on when they get them.
RE: Proboat hydro
well we are not actually supposed to promote other places on here , but since she did anyway , and they are biased here you can email me or pm me and i can tell you a few "good places" to get your props done and purchase them as well..and fwiw .. if you go to a y435/3 blade it is a hell of a lot better in my opinion.
RE: Proboat hydro
ORIGINAL: terry kelly well we are not actually supposed to promote other places on here , but since she did anyway , and they are biased here you can email me or pm me and i can tell you a few "good places" to get your props done and purchase them as well..and fwiw .. if you go to a y435/3 blade it is a hell of a lot better in my opinion. I was not aware this could be turned that far under the water by the proboat .18 engine... Sean |
RE: Proboat hydro
The other thing is, the M435/3 is not a direct bolt on since it is made to fit a 3/16 shaft.
The drive system will have to be replaced or make some shims to fit the prop to the shaft. Dan. |
RE: Proboat hydro
ORIGINAL: Dan S The other thing is, the M435/3 is not a direct bolt on since it is made to fit a 3/16 shaft. The drive system will have to be replaced or make some shims to fit the prop to the shaft. Dan. Sean |
RE: Proboat hydro
ORIGINAL: Sean Bowf ORIGINAL: terry kelly well we are not actually supposed to promote other places on here , but since she did anyway , and they are biased here you can email me or pm me and i can tell you a few "good places" to get your props done and purchase them as well..and fwiw .. if you go to a y435/3 blade it is a hell of a lot better in my opinion. I was not aware this could be turned that far under the water by the proboat .18 engine... Sean |
RE: Proboat hydro
ORIGINAL: Sean Bowf ORIGINAL: Dan S The other thing is, the M435/3 is not a direct bolt on since it is made to fit a 3/16 shaft. The drive system will have to be replaced or make some shims to fit the prop to the shaft. Dan. Sean My bad, lol Dan. |
RE: Proboat hydro
Hay!![X(] He didnt want to go threw ballancing and pollishing props!!:)So I'd sudjested Aquacraft are close to ballanced and there polished,Plus from what I'd read and here on this nitro form,you can just throw the prop on asap,when you get them!!:D Other places like one we cant say isnt cheep and they are having proublems getting people there part on time or anytime at all![:@] And ANY WAY AQUACRAFT is one of R/C U sponcers who advertise on this sight!! Look at the top of this thread!!!:D
RE: Proboat hydro
Actually, ( a moderator can correct me if I wrong) but unless you work for a company that offers product for R/C boats, or you are the owner, or you are sponsored you cannot promote, but
if you are a plain regular RCU member, their is no problem for you to recommend one or more brand or one or more companies. Their is only one company that I know of that which we cannot mention. Dan. |
