Thinking of getting into nitro boating....
I've always wanted to have a nitro rc boat. problem is, I LIVE IN HAWAII!!! all saltwater!!! Would any nitro rc boat be okay in saltwater? or definate no go?
RE: Thinking of getting into nitro boating....
ORIGINAL: dadirtsavage I've always wanted to have a nitro rc boat. problem is, I LIVE IN HAWAII!!! all saltwater!!! Would any nitro rc boat be okay in saltwater? or definate no go? |
If you clean everything with freshwater and lube everything up after a run in salt water it'll be ok
There's a fairly long list of things to do though |
Its no problem to run in salt water if you can find a spot to run in calm water , I havent been to your island but I have been to Maui and did not see too many places to run there.
I hated Maui, I prefer Waikiki.
Hotel in Maui http://kattrourke.com/images/006.JPG Hotel in Waikiki http://kattrourke.com/images/rwghyrtghr.JPG water is calmer on the big island. |
ORIGINAL: BB Modss I hated Maui, I prefer Waikiki. water is calmer on the big island. http://lh3.ggpht.com/_cCYv5Kr2Mdc/SA...w/P4180490.JPG |
HA HA BB you're just a city boy I go to get away from all that civilization he he he .
Hello there... Salt isn't so much a problem if you stay ahead of it. I run in salt water from time to time... Do you fish? If you do, you may be familiar with many products out there to help protect your fishing gear. A spray lube called Reel Magic for example. It is a silicone based spray that helps protect from pitting common with exposure to salt water and air. I spray on the ext. of my running gear and engine (after engine cools). If your are really anal... There is a product for full sized boats called nutra-salt. Its not cheap, but its designed to beak down salt deposits. Injecting thru your water cooling, letting it sit then flush out will keep everything deposit free. The problem with salt is you have to keep in mind that everything is exposed... Not just the engine. Running gear to the control linkages, even the electrical connections for the servos and RX batt... EVERYTHING. As you know living in HI, the salt air over time can do a number on things too.
Good Luck & Hope That Helps John |
ORIGINAL: f16man HA HA BB you're just a city boy I go to get away from all that civilization he he he . I suppose your right. |
| All times are GMT -8. The time now is 06:31 PM. |
