RCU Forums
-   Speed - RC Nitro Boats (https://www.rcuniverse.com/forum/speed-rc-nitro-boats-117/)
-   -   tun fin help (https://www.rcuniverse.com/forum/speed-rc-nitro-boats-117/9201645-tun-fin-help.html)
1150ap 10-25-2009 07:42 PM
tun fin help
Where should the turn fin be postioned on a rigger in relationship to c.o.g.
thanks
Alex
R.J. West 10-25-2009 08:26 PM
RE: tun fin help
Traditionally the turn fin is mounted on the right side sponson transom, assuming your running clockwise.
show us a pic if possible, and let us know which make/size rigger you have, and if you intend to race or just run for fun....</p>
Ron Olson 10-25-2009 08:47 PM
RE: tun fin help
Usually 1" behind the CG.
1150ap 10-25-2009 08:50 PM
RE: tun fin help
Ron the 1 inch is that the leading edge of the fin or is that the backof the fin
toyotatruckin 10-25-2009 09:27 PM
RE: tun fin help
1" behind the CG ron? sure bout that?
Ron Olson 10-25-2009 09:29 PM
RE: tun fin help
OK, I'm getting back into 'riggers after being out of them for a while (see the JAE .12 thread) so I was told 1" from the front of the turn fin to the CG. With the JAE fortunately I have the option of 3 positions to move it around to find which setting I like.
toyotatruckin 10-25-2009 09:35 PM
RE: tun fin help
well your first post said 1" behind the CG
it should be in front of the CG
1150ap 10-25-2009 09:53 PM
RE: tun fin help
wow i just went and measurd it and i have it at 3.5 inches that may explain why it has a mind of its own and turns way to tight
thanks for the help guys
does this 1 inch apply to hydros as well
Ron Olson 10-25-2009 10:16 PM
RE: tun fin help
Thanks Mike as I wasn't exactly sure and started confusing myself! I retyped that I don't know how many times before hitting the OK button as it didn't sound right to me either.
toyotatruckin 10-25-2009 10:23 PM
RE: tun fin help
no problem ron
toyotatruckin 10-25-2009 10:36 PM
RE: tun fin help
basically yes
think like this the boat balances on the cg what ever it may be for the boat its different with all of them, the turn fin is a pivot point when turning if im remembering correctly if its to far forward youll have wide turns to far back youll have super short quick turns or even spin outs and be squirmy which I see you figured out place the Trailing edge forward of the CG a little and tune it from there the 1" may be to far forward but again thats where trial and error come into play you may try and find someone that has a rigger like what ever you have and ask what they run at, that would give you a starting point for yours and make tuning easier
