Sig Four-Star 60
#201
KY
RE: Sig Four-Star 60
ORIGINAL: w8ye
The Four Star 60 is not a plane for more extreme figures anyway. It was never intended to be.
Try a 15-4 on the 75AX
What difference would I see with the 15X4?
My Feedback: (16)
The 15 X 4 should give good vertical and the speed wouldn't be good at all
If you like speed the 13 X 6 should have been pretty good for you?
A 12-7 or 8 might do something for you if you like speed?
I don't have any actual experience with the Os 75ax. My experience is with the Super Tiger and Tower 75's
#203
Bob:
I used the OS website also to select my initial 13x6 and 14x6 props; i'm not complaining about the 14x6 performance. It just that I thought a 75 sized engine on a 60 sized plane would have given very strong vertical
#204
TX
I just finished building a 4 Star 60 kit. I installed a Saito 100 on it and the plane flew great. For quite some time now I've wanted to go gas. The Zenoah G20 was slightly too big to fit on the front of the plane. Once I heard of the Saito FG-20, I ordered it. Has anyone tried this combo on the Four Star yet? Time permitting I'm going to try installing the gas engine this weekend.
#206
TX
The FG-20 only weighs 9 oz (including ignition and muffler) more than the FA-100. CG shouldn't be a factor as I mounted the rudder servo in the tail, and will move the battery aft. I'm powering both the receiver and ignition with one battery (2600mah). Given that the 4* has a very light wing loading, I hope 9 oz. won't effect the flight characteristics too bad. Good weather providing, I'll have a report this weekend.
#207
I'll be interested in hearing about the FG-20 performance. I agree - the wing loading on the 4* is so low that if CG is appropriate, the plane ought to handle a few extra ounces from the gasser. What prop are you flying with it?
#209
TX
I misspoke when I said that I had a 16x6 prop on my FG-20. Instead I have a 16x8. This prop seems to be a bit much for the FG-20, well at least it is running 20:1 Gas/Oil mixture. With this prop the engine idles at 2700 rpm and tops out at 7300 rpm. My next step is to try a 16x6 prop or maybe even a 15x7 3 blade.
It took a little while to get the FG-20 tuned. Now that I have it dialed in, it seems like a good purchase. Hopefully I'll have time to put it in my Four Star 60 in the very near future!
#216
My Feedback: (12)
MT
If it's gas don't waste a lot of time breaking in on the ground, tune it and go fly. Over rich setting don't do them any good either like nitro. Keep rpms low to mid with an occasional full throttle for a few seconds and you should be good after a gallon or so.
Can you get any video, love to see the four star in action.
Shane
Shane
