Prop for a SSE with an OS 70 Surpass
My Feedback: (57)
MI
Does anyone have any prop recommendatons for a Sig Somethin' Extra with an OS 70 Surpass II. My son want to hover it. I was thinking either a APC 11X8 or a 12X7. Being in a SSE, ground clearance is an issue. Thanks
My Feedback: (27)
WI
RE: Prop for a SSE with an OS 70 Surpass
Put a set of Du-Bro landing gear on it to increase the ground clearance and try an APC 13x6 or 13x4W. Works like a charm on mine with a Saito .72
My Feedback: (9)
I use a 13x4W on mine with the Saito 72. I took the gear and reshaped it a little to give the ground clearence. I just rebent it in a vise up by the fuse side. Then pulled the axles out and bent the tab 90degrees to the top plate. It has worked well.
David
David
