Want to add flaps?
CA
Want to add flaps?
I wanted to add flaps to my SS60 i'm building to play around with. I want to split the strip ailerons and was wondering what size the flaps should be?
skeeter
skeeter
CA
RE: Want to add flaps?
I do plan to use seperate servos for each control surface and a programmable Tx, however even with the OS 91 i don't think it will hover.
skeeter
skeeter
Sounds like a cool modification to the SS-60. Another thing that I wish I'd tried with mine is retracts. It would really give the plane a clean look in the air. There is plenty of room in the wing to do it.
Definitely not a hovering type of plane. It excells at more "traditional" aerobatics and things like high speed passes which look especially cool inverted.
CA
Would there be any problems extending the flaps maybe say 1/2" longer in cord than the ailerons, to give it alittle extra surface area?
skeeter
skeeter
I know it sounds hard to believe, but having the inboard 1/3 of a strip aileron will give you more flap than you will need for the GP SS. I use this system on my Ultra Sports and if I drop them too much, I can't get the plane to come down even at full idle.
It's almost comical how slowly the plane will fly with full flaps.
