SuperTigre Engines Support Ask Bill Baxter your questions regarding the SuperTigre line of engines.
2300 Running Backwards
Old 10-13-2004 | 07:46 AM
Default 2300 Running Backwards
Hi,
I have a ST 2300 that runs Backwards every time I start it up. It will flip the correct way eventually. I am running 5% nitro with 18% oil content and an OS F plug. The carb has the newer barrel in it and the motor idles and runs great.
What would cause it to start and run backwards consistently?
Thanks for your help.
Lee
Old 10-13-2004 | 09:43 AM
Bax
Default RE: 2300 Running Backwards
When a large SuperTigre engine starts and runs backwards, it's because it's over-primed. Don't prime as much. You can also flip it backwards, which should help.
It's easy to over-prime the large 'Tigres, and they'll go backwards every time. Pinch off the fuel line and prop the engine until it's dry of fuel. Then carefully re-prime, but not as much. An electric starter will eliminate backwards starting. You can also try opening the throttle a little bit more, too.
Old 10-13-2004 | 11:02 PM
Thanks Bax.
Lee
