SuperTigre Engines Support Ask Bill Baxter your questions regarding the SuperTigre line of engines.
G90
Old 06-04-2005 | 04:16 AM
Default G90
HELLO BILL, HAVE A G90 IN A UCANDO AT OUR FIELD THAT IS BEING STUBBORN. THE TANK IS MOUNTED HIGH IN THE FUSE WHICH CREATES A SIPHON AFTER PRIME. ONLY AN ISSUE WITH RELIABLE IDEL HERE. THE OWNER IS NOT WILLING TO MAKE MODS TO THE AIRFRAME
(MAYBE NOT CAPABLE EITHER), SO I WAS WONDERING IF YOU HAD ANY SUGGESTIONS?
Old 06-06-2005 | 10:27 AM
Bax
Default RE: G90
If a too-high fuel tank position is causing problems with idle and midrange, there's not a lot that can be done without moving the tank, moving the engine, or going to a regulated fuel system. Sorry, but that's something with no easy answer.
