SuperTigre Engines Support Ask Bill Baxter your questions regarding the SuperTigre line of engines.
2000
Old 11-23-2002 | 03:16 AM
atvracer's Avatar
My Feedback: (17)
Default 2000
hi
i'm looking at a St2000 are these motors any good
and what prope size and what rpm should it get
thanks
atvracer
Old 11-25-2002 | 07:30 PM
Bax
Default 2000
We'd run a 16x8 propeller, and expect to see RPM in the high 7,000's.
The SuperTigre S2000 is a fine engine, and will give years of service when broken-in and cared for properly.
Old 01-01-2003 | 05:59 PM
Default 2000
Bill
Excuse me butting in.
I need to know if the 2000
2300 and 2500 weigh the same.
I dont want to add any weight to
my plane for balance.
John Jtroush
Old 01-02-2003 | 04:38 PM
Bax
Default 2000
John,
The SuperTigre S2000 and S2500 weigh 1,248 grams without muffler. The G2300 weighs 1,073 grams without muffler.
Sorry, we don't have a weight on the mufflers....we'll have to get that checked and added to the specs.
Old 01-26-2003 | 10:12 PM
My Feedback: (15)
Default prop size
mr bax
a S2000 will spin an 18X8 wont it???
Old 01-27-2003 | 09:24 PM
Bax
Default 2000
markdam,
We believe that an 18x8 prop is just too much for for the S2000, which, after all, is just 20cc in displacement. If you ran such a large propeller, the RPM would be too low for the engine to generate reasonable power to fly any model.
The 16x8 is just about the right prop to start with. It allows the engine to turn in its best torque band.
Old 01-29-2003 | 04:57 PM
My Feedback: (15)
Default thanks
ill let you know which prop works
Old 02-01-2003 | 05:09 AM
My Feedback: (15)
Default hmmmm
I still cant get over how 3 ccs can make THAT much difference but i guess the 2300 is ported different? it will spin an 18X8
Old 03-18-2003 | 12:35 AM
My Feedback: (15)
Default Baxter?
3 ccs makes that much of a difference? i know they are ported different a 2300 will spin an 18x8
Old 03-18-2003 | 04:56 PM
Bax
Default 2000
The SuperTigre S2000 and G2300 are very different engines. There is a large difference in porting.
The S2000 was intended for sport use in larger models, with a mild fuel. The lower combustion pressures and power output were what contributed to the engine's lower oil requirement.
The G2300 was intended to be used in FAI pattern, but as a more economical answer than the O.S. or YS FAI engines. It's porting was developed to that end. That's also why it requires a regular 2-stroke glow fuel instead of the low-oil "ST" type fuel.
