Supertigre 61 wont run in high speed
My 61 engine is tested and tuned. When I put the glow starter on it, and start it, it runs perfectly as long as the starter is on. Wshen I stake it off, low idle is good but as soon as I go into high run (medium to high) it dies like it just ran out of fuel. I have changed plugs, and currently have a hot plug on it. Anyone.........please help!!
RE: Supertigre 61 wont run in high speed
You may have a bad glow plug, so try a new one.
Your carburetor may not be adjusted correctly. Here's how to do it right:
http://www.rcuniverse.com/forum/m_1579985/tm.htm
