need help with trex600e and viper 1300kv
Hello evrey one i need help with my trex600 and new viper vsh6013 1300 kv cuase the motor and ecs are runing very hot after couple flight.My Set-up trex600e,viper vsh6013 1300kv,castle creation ice 100 amp,170t main gear,16t pinion gear, external bec ,6s 5000mah 40c,head speed 2000,2100,2200.
and what isthe timimg and pulse width should set at?
RE: need help with trex600e and viper 1300kv
i don't have any of that stuff, but on my 450 with the stock align brushless 430XL motor, the ESC's and Motor's heat sinks are too hot to touch for more than a second. i just let it cool in between flights. </p>
hope that helps</p>
Thanks you for your time, a guy @ the field trex600e set-up, castle creation 100 amp stock motor 5000 mah 40c 16t pinion and 170t main gear and he was doing very hard 3d after flight his ESC is not even hot.I guess Viper vsh6013 1300kv just a brand new motor on the market once again thanks.
CA
You're running too large of a pinion for that kv motor. On the stock 1220 kv motor you didn't want to go above 15 teeth on the pinion. Leave timing and pulse width on their default values.
Yeah..16t pinion is to large for the motor,change to 15t pinion the motor & ESC seem to be ok with the temp.Viper vsh6013 1300kv is very quite than other brand love it thanks.
Glad you got it sorted..
i had a similar problem with a Gaui 550 and a 1600Kv motor running a 13T pinion..
I have 100 amp ESC and this combo was running crazy hot.. both the motor and ESC were too hot to touch and I only got about 4 minutes flying time.
I changed to a 600 sized motor, 1100Kv, put a 14T pinion and upped the throttle curves to give me the same Rotor head speed..
it made a phenomenal difference.. the motor and ESC run completely cool and I now get 8 minutes flight time easily..
here is vid of the 2nd flight with the new motor... http://www.youtube.com/watch?v=Pn1ngAwJ_cg
I couldn't beleive a larger motor would be so much better..
