3GX flybarless system
Have 600ESP with Align 3GX and DX8 radio.Tail will drift intermittently and I thinkthe problem is with the3GX. Where can I send the3GX for service / support? Was purchased with the heli and have no receipt for the 3GX.
Thank you.
Lt.</p>
I would check your gyro gains, but I am not so sure whether its done in the 3GX unit or the DX8. My guess would be that its all done in the DX8...
How did you get it to work with your Spektrum Tx? I gave up. The manual shows to add a satellite, or even use two satellite receivers when using Spektrum. I have the Dx6i and I have given up getting it set up with an AR 6100 Spektrum receiver. I am buying Futaba.
The problem was with the radio (DX8). It works well after having the DX8 repaired under warranty. Aux 2 has to be the gain channel.
Lt.
Lt.
What was specifically wrong with the DX8 if it was a setup error with the Aux2 being the gain channel?
Was it a case of not RTMing or was it a technical fault with the DX8
A mate of mine ended up having to have his antenna replaced on his DX8 when he tried to bind one of his BnF aeroplanes. The DX8 failed to do so because you need a pure signal from the transmitter.
