Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 TRACK AND BALANCING BLADES >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 03-06-2006 | 04:37 AM
Default TRACK AND BALANCING BLADES
JUST LOOKING FOR SUGGESTIONS ON WHAT EVERYONE USES FOR WEIGHT WHEN BALANCING THEIR ROTOR BLADES. DOES ANY KNOW?
Old 03-06-2006 | 09:27 AM
Default RE: TRACK AND BALANCING BLADES
weigh each blade on a digital scale add mylar tape to light blade. some use lead drilled into blade but if it gets out you have flying shrapnel
Old 03-06-2006 | 03:08 PM
I use a little E-flite balancer and tiny strips of Mylar covering on the light blade does the trick.
Lloyd
Old 03-07-2006 | 07:28 PM
You need to find the cg of the blade and add the weight there. Not at the end of the blade. A little bit of tape usually does it.
