Futaba 6XAS and the Trex
I have a Futaba 6XAS and was wondering if any of you own this tx and know how to setup it up
for Normal flight, 3d flight. etc on it. thanks
Jordan
Jordan
UT
RE: Futaba 6XAS and the Trex
I have this TX and use it to fly my T-Rex 450XL CDE. I have normal, Idle up and Throttle Hold all configured. It handles the heli great with no swash interaction that I can see. While it doesn't have a whole lot of bells and whistles for Heli's it's a good radio for me. Took a while to figure it out, but I tried it first on a Blade CP and it flies that bird perfectly as well.
Since there are so many settings to configure to trim the heli right I put it in a spreadsheet so I could keep track of my config. I''ve copied in the configuration I have below. Just so you're aware, I'm using the GY401 AVCS gyro and an R146iP receiver with all Futaba S3110 servos. Flies great with this combo. I have it set so I get the full pitch range on my heli without binding, and it's also just set for my flying preferences.
*Disclaimer* Don't forget - this is the setup that works for me. Just use it as a guideline. Just because it's working for me doesn't mean it's the perfect configuration. After initial setup, test test test. As I'm sure you know - a big part of a good flying heli is the setup. I spent a good deal of time tweaking the heli as well.
PARA Menu
DRSW 2 Dual Rates - assign dual rates to 1 switch rather than separate switches
HELI Set Heli Mode
MOD C CCPM
SWSH Menu
SWSH 3 3s 120 CCPM
SWSH AFR Values
Ch1 +50
Ch2 +50
Ch6 +50
Hovering Pitch
HV-P -100% Adjustable - set via trim pot on Tx (Flap Trim during acro mode)
Rudder Offset
R-OF Inh Inhibited for HH Gyro
Revolution Mixing
REVO Inh Inhibited for HH Gyro
Throttle Hold
Ch3 0% Set to zero for Electric
Idle Up
Ch3 100% Curve
Hovering Throttle
Ch3 +60%
Pitch Settings
PI-N 72% U Pitch-Normal
30% D
PI-I 72% U Pitch-Idle Up
80% D
PI-H 72% U Pitch-Throttle Hold
80% D
Subtrims
Ch1 -114%
Ch2 +64%
Ch3 0%
Ch4 0%
Ch5 0%
Ch6 -44%
Channel Reversing
Ch1 N
Ch2 R
Ch3 R
Ch4 R
Ch5 N
Ch6 R
Exponential
Ch1 Low Rate -30%
Ch1 High Rate -30%
Ch2 Low Rate 0%
Ch2 High Rate 0%
Ch4 Low Rate 0%
Ch4 High Rate 0%
Dual Rates
Ch1 Low Rate 100%
Ch1 High Rate 100%
Ch2 Low Rate 100%
Ch2 High Rate 100%
Ch4 Low Rate 100%
Ch4 High Rate 100%
ATV Rates
Ch1 Up 100%
Ch1 Down 100%
Ch2 Up 100%
Ch2 Down 100%
Ch3 Up 100%
Ch3 Down 100%
Ch4 Up 60%
Ch4 Down 60%
Ch5 Up 54%
Ch5 Down 50%
Ch6 Up 100%
Ch6 Down 100%
PARA Menu
HELI Set Heli Mode
MOD C CCPM
SWSH Menu
SWSH 3 3s 120 CCPM
SWSH AFR Values
Ch1 +50
Ch2 +50
Ch6 +50
Hovering Pitch
Rudder Offset
Revolution Mixing
Throttle Hold
Idle Up
Ch3 100% Curve
Hovering Throttle
Ch3 +60%
Pitch Settings
30% D
80% D
80% D
Subtrims
Ch1 -114%
Ch2 +64%
Ch3 0%
Ch4 0%
Ch5 0%
Ch6 -44%
Channel Reversing
Ch1 N
Ch2 R
Ch3 R
Ch4 R
Ch5 N
Ch6 R
Exponential
Ch1 Low Rate -30%
Ch1 High Rate -30%
Ch2 Low Rate 0%
Ch2 High Rate 0%
Ch4 Low Rate 0%
Ch4 High Rate 0%
Dual Rates
Ch1 Low Rate 100%
Ch1 High Rate 100%
Ch2 Low Rate 100%
Ch2 High Rate 100%
Ch4 Low Rate 100%
Ch4 High Rate 100%
ATV Rates
Ch1 Up 100%
Ch1 Down 100%
Ch2 Up 100%
Ch2 Down 100%
Ch3 Up 100%
Ch3 Down 100%
Ch4 Up 60%
Ch4 Down 60%
Ch5 Up 54%
Ch5 Down 50%
Ch6 Up 100%
Ch6 Down 100%
