Trex Blade tracking adjustment problem
I have recently noticed when checking the tracking of my trex that if you hold the heli sidewise and power up to at least past 50% power the tracking of the blade tips in the forward path of the blades is perfect but the tracking on the tips on the aft path is slightly off. Not much ,just maybe 1/8 of an inch. Cant seem to get both fwd and aft perfect tracking. Does anyone have any suggestions as to why they would track like this and the way to correct this problem?
Thx
Thx
My Feedback: (9)
GA
By holding the heli you put a load on the main blades. In the forward path the blades will track fine but like a gyroscop a force applied will affect 90 degrees after the applied force leaving the rear path out of track. NEVER HOLD YOUR HELI WHEN THE BATTERY IS PLUGED IN!.
Make sure your FlyBar holder is perfectly flat. Loosen the 4 screws and flatten it by eye, then tighten screws. I had the same problem, fought with it for hours.
