Trex SE Tail Servo Linkage
OK
I'm in process of completing my rex but was curious about the servo rod on the tail. Is a Z bend required or can i make a rod using ball links on both the tail and the horn?
Kind Regards
Kind Regards
KY
I think anyone would be silly not to make their own ball link setup for the tail servo.
I did it on both of my Helis. Align gives you enough parts to do it, and it's a much better setup than the standard z bend.
I cut off the little plastic clips that are supposed to support your tail push-rod too......it puts too much of a bind on the rod in my opinion. Off with it's head! :-)
