trex battery issues
ok so i bought this battery from milehighrc (www.milehighrc.com). It is a 2200 mah 10c constant and 15c burts. I am running a align 3550 kv motor with a 35 amp align esc. It ran great on a low brake, High output, high discharge on my battrey that came with the heli. But then when i hooked the milehigh batt. Up to it the battery cought on fire!!!! Could this be because I have it set to a high discharge rate? What are the rate anyway? For example low discharge = 5c, med dis=10c high =20c? What are they? Should i have the head speed on the esc set to medium and discharge set to medium? Help please! Thanks
Todd
Todd
