Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 speed control choice >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 06-02-2006 | 12:02 AM
rockhouse's Avatar
Default speed control choice
Just bought a new se. It comes with an align 35 esc. I have a castle phoenix 35 esc. Which should go in the bird?
Old 06-02-2006 | 12:14 AM
Default RE: speed control choice
Phoenix better & more versatile.
Lloyd
Old 06-02-2006 | 01:06 PM
Over all the Phoenix 35 seems like the better choice. I don't know anyone really that uses the Align 35 ESC. The Phoenix 35 offers more choices in setup , and with the castlelink cable the programing is easy. I would recommend using the Phoenix and keep the Align for an emergency backup.
Old 06-02-2006 | 02:17 PM
VinceHerman's Avatar
I use both. I do like the Phoenix setup better, especially with the Phoenix link.
The Align does have some advantage. It has a softer start. Really slow spoolup that does not twist the heli with you first start.
It can handle more current through the BEC. This might be because I have a slightly older Phoenix. Don't know about the newer ones.
Vince
Old 06-02-2006 | 09:35 PM
The latest firmware revision for the Castle Creations controllers addressed a few different issues. Most noticeable is the improvement in the governor mode. My battery temps dropped about 20 degrees F when I updated it. The soft start option is great as it eliminates main gear teeth getting ripped off. The spool up speed on the fastest setting is still a little too slow for my liking. I'm hoping that will be addressed in the next revision.
As mentioned by the others, the $20 Castle Link USB interface makes it so easy to change settings as well as save them. This allows you to easily try different settings combinations.
Old 06-02-2006 | 09:44 PM
The newer Phoenix 35 offers 3 start options Fast start, Soft start and Very Soft start and the Phoenix 35 offers 3A vs the Align 35s 2A.
Old 06-03-2006 | 07:36 AM
The Phoenix 35 BEC actually has two regulators. If one gets overloaded, the other kicks in. This information came in a response from Castle Creations when I questioned them as to how their BEC's worked.
