Blade tracking
I have been having some trouble tracking the blades on my t-rex. I notice in the instructions it talks about a fine and course adjustment. My blades are out of track, when using the fine adjustment the blades are either out of track one way of by making the smallest adjustment possible they are out of track the other way.
Any advise on how to get the track correct?
What kind of blades are you using? the linkages going to your blade grips from the fly bar control lever should always be turned in full turns, sometime this is to much. so you can adjust the linkages going from the swash plate to the flybar control arms half turns. that should fix it. If you are trying to track the stock plastic fiber blades they can be a pain in the ***** sometimes. woodies i think are eaiser, and CF are the eaiset I think. It also might help you to look the bob finless videos on blade tracking.
