Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Align esc/motor setup problem >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 08-11-2006 | 10:29 AM
Default Align esc/motor setup problem
setup brushless 420lf Align motor & bl25t esc per instructions.Problem is when I throttle up speed stays low & doesnt change.Am I missing something?Thanks for anyones ideas.
Old 08-11-2006 | 11:55 AM
Default RE: Align esc/motor setup problem
Any chance it's your throttle curve??? Also check for smooth gear mesh and belt mesh. Are all parts lubricated and running smooth? Be sure your running mid timing on the motor, low timing may cause this problem?
Old 08-11-2006 | 11:32 PM
Crash9's Avatar
I had a problem like that and it turned out to be my 25a ESC. I switched to the 35a and no more trouble. But check your gears etc. like the above post say's.
