450 SE short boom
TX
450 SE short boom
Broke my belt. I have a short belt & short boom from another trex. What will I get from the short boom setup? Is it desirable? Should I wait & get A long belt?
CA
RE: 450 SE short boom
You want the long boom anywho, gives faster tail response (Idea of levers applied with the tail boom. The short boom is a short lever and therefor won't move the nose as much as a long lever/long tailboom would.)
My Feedback: (182)
Isn't it opposite? Given the rpm based on the main rotor speed (gear ratio) we can ge the tail rotor rpm. If the short belt is has same tooth / inch or whatever the measurement, the tail rotor will turn same rpm as in the loner boom.
In a circle, it takes longer to run following the circumference of the circle if you are on same speed, so longer tail boom actually give slower response.
I think the longer tail boom should ease up the force need to move the tail. Maybe this is why?
Just a thought.
Ihncheol Park
Just a thought.
Ihncheol Park
CA
Exactly
You are right though now that I think of it I DID have it backwards, lol. I dunno, I just remember Align advertising that the longer boom was supposed to give more control (perhaps they meant more accurate???)
