T-Rex heli For all you T-Rex lovers out there, this where you can post!
TREX help
Old 08-31-2006 | 09:39 PM
Default TREX help
I just got a Trex and I have a problum that I dont under stand how to fix. Useing the rudder the helli will spin like it should to the left and very slow to the right. Is there some kind of setup with the gyro I am over looking.
I have a futaba 9c radio and Align rce-500x Gyro
Old 09-01-2006 | 06:30 AM
WhtBronco's Avatar
Default RE: TREX help
I'm not sure about that gyro, but check to make sure the ATV's on the Tx are set to 100 each. Ensure the servo horn is centered and that you have near equal throw each way on the tail rotor slider. Generally you'll need a bit less throw for the nose to go to the right than the left for the same piro speed.
Old 09-01-2006 | 07:31 AM
It seams like the blades would need to be ajusted but I dont see how that can be done. No mater how I set the radio the blades will only go so far.
Old 09-01-2006 | 10:50 AM
I got it!
