pinion keeps coming loose
any idea how i can get the pinion on tight(motor shaft keeps spining in the pinion) cant seem to tighten the set screw enough before the hexagonal wrench slips in the srcew tried screw loc
ON, CANADA
RE: pinion keeps coming loose
ORIGINAL: foxman50069
I bought a hex driver set from Hudy. They're expensive but very good quality. I also bought a set from Align. They were only $38 and seem as good as my $150 set from hudy, and they have colour-coded handles, nice to tell which one is which.
With either set, I can crank down so hard on the pinion grub screw I worry about snapping the tip off the tool! It will not slip in the socket head of the screw.
Get a new pinion/set screw while you're at it. The pinion is prob fine but I wouldn't risk the lhs giving you an inferior qualilty (less than grade 8 hardness) set screw.
Use Locktite blue, good tools, a new screw, and this problem will
disappear for good!
Signa
T-rex 450 SE
IL, WESTERN SAHARA
Another option is to file a small flat on the motor output shaft. A dremel tool with a grinding stone also works.
It will never slip again !
