T-Rex heli For all you T-Rex lovers out there, this where you can post!
240 or 401
Old 09-08-2006 | 12:21 AM
rockhouse's Avatar
Default 240 or 401
Running an SE with a 240 gyro. Just updated the tail servo to a 9650. Would I gain anything by going to the 401 other than gain adjustment on the radio?
Old 09-08-2006 | 02:18 AM
Default RE: 240 or 401
I'm not familar with that one but this is how I see it
if the 9650 is digital,than yes,you would gain the speed of the servo to control the tail under hard 3d.if you are only doing fff/circuts you won't gain anything noticeable
if it's analog,no, you have no reason to go to a 401 unless you are having issues with wag/overshoot
Old 09-08-2006 | 10:02 AM
BarracudaHockey's Avatar
9650 is a digital tail servo. You will get better holding and faster tail response, also the 401 has adjustments that the 240 lacks, over all its a much better gyro.
Old 09-09-2006 | 04:13 AM
PsychoRookie's Avatar
For the diminutive amount of price difference between the two, I would definitely go with the 401. Don’t waste your money on the futaba servo it will be overkill! Buy a cheaper digital servo, and save your money for repairs. I would not worry about the futaba servo unless you do aggressive flying that demands quick hard response.
Old 09-09-2006 | 02:42 PM
My Feedback: (197)
ORIGINAL: PsychoRookie
What other would you recommend
Old 09-09-2006 | 08:42 PM
401 , 401 , 401 !! dude they are choice , servos grab a hds-577 ive got one on my tail with my 401 , around 30$ us
[link=http://www.wattsuprc.com.au/product_detail.asp?pid=TADS02]hds - 577 digital servo[/link]
switch the gyro to high frame rate mode (digital) set the centre point , gain at 70% Tail lock and forget your tail !!!
also you cant use a JR digital on a 401 either wrong signal timing ..
LOL's
Toooo Easy .
Jason
Old 09-09-2006 | 08:44 PM
I use the HDS-877 on my rex and am very happy with its performance. It actually has a faster response speed than the Futaba s9650 but half the torque. you can look at stats of the servo is at this link. [link]http://www.helidirect.com/product_info.php?cPath=48&products_id=435[/link] If you need more torque, then you can try the HDS-577 (I have not used this one though) the link for the HDS-577 is [link]http://www.helidirect.com/product_info.php?cPath=48&products_id=1119[/link] I hope this helped.
Old 09-09-2006 | 10:18 PM
From what I am getting you have a GY240 on your T-rex right now. And you just added the 9650 futaba tail servo.............BAD IDEA
The GY240 is not compatable with digital servos. I would stongly recommend putting the GY401 on it immediatly before any further flights. So far that is a setup that is pretty much impossible to top at this point in the game. Untill a lighter "9650" comes out. If hitec would hurry on theirs......we would be all set
Old 09-10-2006 | 11:22 PM
rockhouse's Avatar
The reason I went to the digital servo is because I have a slow yaw rate. The servo did nothing for that. My throws are to the stops on the tail with my ATV's set at 100%. I noticed that if I lowered the ATV's much the tail was very slow. In order to use 100% on the rudder I had to move the ball link in a bit on the servo. What can I do to get a decent pirouette? Right now it takes a second or two to spin. My raptor 60 is more than twice as fast. BTW this is a Trex 450 SE.
Old 09-11-2006 | 10:40 AM
You can lowering the gain a bit.
The 240 will work with digital servos, its not incompatible, you just wont get any benefit by spending the extra cash.
Old 09-11-2006 | 07:30 PM
your head speed is TOOO LOW !!!
my trex just whipps around , !! it must be your head speed , or you have some crook lipo batterys , just by adding flight power lipo's to my bird i had to back off my throttle curve to stay under 3000 head speed , im down at around 50 % throttle to hover and 80% throttle to fly aggressive
the batts can make that much of a difference
Jason
