Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 9C throttle hold prob. >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 09-20-2006 | 12:22 AM
rockhouse's Avatar
Default 9C throttle hold prob.
I'm trying to set up my throttle hold on my SE. The hold works fine except for a bonus feature - it throws 10 degrees negative pitch whenever I hit the switch. What gives?
Joe
Old 09-20-2006 | 12:58 AM
Default RE: 9C throttle hold prob.
that is standard operation,you get full neg and full pos pitch on the collective limited by the PIT setting in the SWASH menu.you need to go in the "advanced settings"and set the "pitch curve" with the "hold on" to allow only the amount wanted(just like doing a regular pitch curve make sure you select HOLD not NORM,IDL1,etc)or remember that you need to hold just under center stick to maintain a slight neg pitch on the fall down.hope this helps
Old 09-20-2006 | 08:50 AM
rockhouse's Avatar
perfect. Thanks
Old 09-20-2006 | 11:01 AM
BarracudaHockey's Avatar
Yes, each flight mode, including TH has its own pitch curve.
Old 09-20-2006 | 09:38 PM
rockhouse's Avatar
Boy this thing doesn't auto near as good as my Raptor 60!
Old 09-21-2006 | 07:35 AM
It autos like a homesick lawn dart
