T-Rex 450sa PROGRAM on a Futaba 9C
Would someone kindly point me in the right direction or provide, if they have, the complete programing for a stock 450sa on the Futaba 9c. I am thinking of giving myself the T-rex as an early Xmas present LOL and I would like to have the radio ready. Thansk guys.
GA
not something that can be "given" as each setup is different...
Using a pitch gauge....
Set up throttle curves and pitch curves to get the headspeed where you want
I run -4 to +9 degrees in normal mode, with head speed around 2400 rpm
in idle up mode, I have it set to -10 to +10 degrees with headspeed around 3000 rpm
GA
exactly.....
you set up a throttle curve and pitch curve in normal mode and idle up mode using the above numbers
there is no set numbers that everyone with a 9C uses..... what is set on my 9C with my Trex will be different from yours....
