Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Help with pinion sizes and application... >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 01-17-2007 | 02:48 PM
Default Help with pinion sizes and application...
I am looking for pinions for a couple of T-Rex 450s. One of them is a 450SE and the other is an XL. I have several motors and need help (1) identifying pinion sizes and (2) finding a place to purchase them. I would also appreciate some advice on recommended pinion sizes - keeping in mind I occasionally add a additional 10-11oz to the SE for Aerial Photography equipment!!! Here are the motors:
Align 420LF
Align 430L
Medusa MR-028-032-3400
AON "Vertical" V2815-3500 (I believe uses 3.2mm pinion)
Thank you for your assistance
Old 01-20-2007 | 11:04 PM
Default RE: Help with pinion sizes and application...
motor gear ratio for general flight in the align manual is 4000-4200KV use 9t 3500-3800KV use 11t 2800-3200KV use 13t 2300-2500KV use 13t. the only diffrence it says for 3d flight is in the 2800-3200KV range may need 13t/15t. hope this helps
