Battery Alarm
OR
Here is a cool li-po battery alarm. Avaialble at http://www.heliproz.com/prodinfo.asp?number=335444 . No more wondering when to land or worry about battery damage. Well worth the money and it works great.
Heres the one im using. 35NZD.
http://www.rchelis.co.nz/product_inf...roducts_id=384
Its not the prettiest but it works. 5 LEDs may help to see in the bright sunlight.
Ive set it to approx 10.4V. This requires 80% of the battery capacity to charge.
I have seen this figure recommended on this and other forums.
Cheers
Cheers
I use this one
Apogee LOA Loud Obnoxious Alarm LiPo
http://www2.towerhobbies.com/cgi-bin...p?&I=LXMHJ9&P=
ORIGINAL: Heli_Harry
I use this one
I use this one
OR
The one from Heliproz has adjustable voltage and is loud and obnoxious as well. It also has a neat feature, the alarm sounds as you approach your set voltage by a series of beeps that increase to a steady tone as you get to your actual voltage setting.
I like the sound of your Heliproz.
ORIGINAL: orstraycat
