AR7000 help
FL
yesterday my AR7000 worked fine and today i mounted it into my heli with some velcro and plugged everything in and it wont work!!! the light on my GY401 lights up and the lights on the AR7000 blink right when i plug the battery in but then they stop. I get no response whatsoever from any of the servos or the motor. I thought it was the rx battery being almost dead that was making it do this but when i plugged in my lipo it did the same thing!! I also tried removing it from my heli to see if that was the problem, with no luck. Anyone know what the problem might be??
FL
ya... But isnt it supposed to blink when you turn the rx on before the tx is turned on? mine doesnt blink or anything... but it will give power to the gyro and to the esc... owell
Yes it will blink if you have the binding plug pluged into the batt then turn on the TX while holding the bind button in the back. You might want to try to unplug everything from the RX and try again.
FL
omg!!! i followed the directions for binding to the "T" and nothing was working. I must have tried it at least 20 times last night and this morning with no luck... So this afternoon i went to the lhs and bought an AR6000 and i decided to try to see if the AR7000 would work one last time and amazingly it did!!! I guess the AR7000 was lonely and just wanted another receiver to play with
... o well i guess i have a backup now
