Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Battery Mounting? >
Battery Mounting?
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Battery Mounting?
Old 03-24-2007 | 10:56 AM
Missileman's Avatar
Default Battery Mounting?
Please help
I am using 1320 mah packs on my 450 and want to upgrade to 2100 mah packs.
Problem is the packs are much longer and if I try mounting them flat they fit under the canopy but the heli is extremely nose heavy.
I can't seem to figure out another way to mount them.
Anyone using the 2100mah long packs could you please post a pic of how you have your battery mounted.
PS: I have an XL so it doesn't have an adjustable battery tray.
Old 03-24-2007 | 12:29 PM
Default RE: Battery Mounting?
I just rigged up a used Trex 450X that I got on the cheap and added a CommonSense 2100 mah. I just keep is short of butting up to the motor and let the fron hang over. If you pick up the heli by the blade holders it hangs real level.
Kurtzz
