What are the main differences of the T-rex se v1 and v2
hey
there are many t-rex 450 se kits here in china, but there are very few v2's. What are the main differences between these kits
Dan
Dan
SE V2 - New features over SE:
1.New metal head stopper
2.New main rotor head assembly (4mm feathering shaft + thrust bearings)
3.New main drive gear (newest SE has this)
4.New fiberglass painted canopy
5.New anti-rotation bracket (taller)
6.New high strength main frames (more CF material around the two front servo holes)
7.New split upper bearing block for tail drive gear assembly (So you can fit pre assembled tail pulleys in nice and easy.)
8.New longer, c.g. adjustable battery mounting plate
9.New higher strength landing skid
10.New tail boom mount (same one as SE just inverted)
11.New tail servo mount with dual fixing holes (apply to S9650)
12.New tail pitch assembly & new c.g. amended tail blades (newest SE has this)
13.New vertical/horizontal stabilizers
14.New wear-resistance ball links
15.Improvements for some parts and bearing precision
MI
If there is a bug i have yet to find one. Great flying heli. The things i like the best are the new main get that is much truer and wobble free. The beefier frames are not that much thicker but its something and it fixes the weak point in the upper battery mounting position. The tail case is extremely smooth with my 9650 and the tail mounts are a perfect fit for that servo now. Over all it is worth the extra money. It isn't much more and is definitely worth it.
Yeah, the V2 is an improvement on the SE which was an improvement on the blah blah blah. Don't think there are any bugs out there in it that I have heard of.
I have an SE and a V2 ... both are great.
ok, so i would have a fine Heli Ethier way, with not that many bugs?
Also I can not tell if this heli is a V1 or V2. It says v2 on the title, but its got v1 box and crap
http://www.atomichobbies.com/KX01503...p_69-948.html#
Thanks for all the help
Dan
Dan
ON, CANADA
The parts in the pictures are SE V1 parts. (head button, ESC)Those are just what I noticed with a quick glance. I'd say it's not an Align New V2, if the pictures are correct.
George
George
