Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Can't control my rex >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 05-01-2007 | 09:05 AM
Default Can't control my rex
I was able to hover my T-Rex 450 XL HDE pretty good, than had a crash into the fish tank (LOL). I replaced a broken tail housing and rudder blades. While waiting on parts I replaced the servos that came with the dx-6 for Hitec 65's. When I throttle up my heli want to immediately flip over to the left. If I didn't have on trianing gear it would have crashed. I checked over everythings made some adjustments and it still want to tip over to the left. I can even make adjustment on my tx and it still wants to tip.
Old 05-01-2007 | 09:40 AM
HeliTB's Avatar
Default RE: Can't control my rex
Let me ask a few questions.
1. Unplug the motor and raise throttle stick. Look and see if the swash is level during the full travel. Is it level?
a. Low stick
b. Mid stick
c. High Stick
2. Did you ensure your servos arm are at 90 degrees at Mid Stick? Subtrim can help with this if you can't do it mechanically.
3. Did you reset all trims and subtrims to zero when you installed the new servos?
4. My first question should have been is this CCPM or Mechanical Mixing?
Old 05-01-2007 | 09:45 AM
Rafael23cc's Avatar
When you changed the servos, you plugged them in the wrong places on your receiver, or some of the suggestions above.
Rafael
Old 05-01-2007 | 10:27 AM
gixxernoob's Avatar
ORIGINAL: supaman2u
I used the spektrum servos before and when I changed it to HS65 I have to reverse the settings on the DX-6 here are my settings using HS65's.
Servo Reversing:
THR: Norm
AIL: Norm (HS65 Servos)
ELE: Rev (HS65 Servos)
RUD: Rev
Ger: Norm
PIT: Rev (HS65 Servos)
Old 05-01-2007 | 09:00 PM
I try above stated thanks for the information.
