T-Rex heli For all you T-Rex lovers out there, this where you can post!
closed...thanks
Old 05-05-2007 | 06:44 PM
Default closed...thanks
Im getting a little front to back wobble ....changed head speeds, gyro adjustments...paddle adjustments, ...any thoughts...dave
Old 05-05-2007 | 08:13 PM
Default RE: Help...a little front to back wobble on my v-2
I have the same problem. FYI, I am using 3 HS-65 MG on the cyclic, very solid no play at all. The tail servo is a HS-56, I will upgrade it if necessary. The wobble is obvious in hover, but not so obvious (or present) in forward flight. Idle-up is more solid. It becomes the worst when the battery dies down towards the end. I am suspecting that servos don't have enough holding power when voltage drops? I am really not sure. Please help. Thanks.
Old 05-05-2007 | 09:10 PM
ORIGINAL: dave3913
by front to back, you mean nose is bobbing up and down?
Pete
Old 05-05-2007 | 09:12 PM
ORIGINAL: honghui
Again, same question is it nose bobbing up and down, or tail wobble side to side? When the battery gets to the end if you are using Align ESC, it is normal for it to surge for 10-15 seconds when batt low warning kicks in. If it is a tail wag, or tail moving from side to side, try turning down the gain on the gyro.
Pete
Old 05-06-2007 | 06:31 AM
As Dave3913 elluded to, see sawing or front to back, is either low head speed or tight head dampening. Check out your see saw to be sure it is free in movement as this can cause oscilating, moving around in a circle if veiwed from above, which can look like bobbing at an eye sight level.
For our info, can you give us an idea of your head speeds? If no tach., pinion and motor kv. as well as throttle curve?
Old 05-06-2007 | 09:59 AM
Thanks guys,
I have a tach and I have run head speeds from 1800 to 2600..no change....nothing unusual with the head...and it is front to back....Ive never crashed....barely a hard landing.....I use pro wood blades.....3400 kv motor...staight line throttle curve...twleve tooth pinion
Old 05-06-2007 | 10:30 AM
I would keep my head speed up above 2200 minimal.
Are you using the stock o rings with 1.5 mm spacer?
Old 05-06-2007 | 10:34 AM
Yep, no slop at all
Old 05-06-2007 | 10:38 AM
Ya, I just noticed it's a V2, not framilar with the head dampening. I assume it's stock. There should be some up down flex relative to being 90 degrees from main shaft.
Old 05-06-2007 | 11:09 AM
Im going to try replacing the main shaft....see what happens...thanks..dave
Old 05-06-2007 | 11:51 AM
Oh, that reminds me, take a look at your tail shaft. It can cause a little woble with a slight bend, being that leverage amplifies it.
Old 05-06-2007 | 06:51 PM
Thanks guys...got it figured out....gosh I hate those little glitches...
Old 05-07-2007 | 06:01 PM
armycopter's Avatar
Default RE: closed...thanks
What was it?
