Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 450sa upgrade question >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 06-05-2007 | 01:42 AM
Default 450sa upgrade question
I have a 450sa and was wondering if it was the same as a 450se just without the aluminum and the fact that it is arf? I was just wondering what aluminum upgrade parts i should get for it, the se, x, xl?
Old 06-05-2007 | 06:17 AM
HeliTB's Avatar
Default RE: 450sa upgrade question
450sa is the same as 450se, but without the aluminum (bling). If I were to recommend an aluminum upgrade it would be the Flybar Control Set AGNH1216G and the Flybar Seesaw Holder AGNH1217G. They break rather easily in crash. Blade Grips do as well.
Old 06-05-2007 | 06:43 AM
soneebee's Avatar
This is my 450S fully blinked.. only difference with the SE is the frame... V2 version.
tail assembly is nice too.. the design is similar to the V2 tail case. so I guess the CopterX heli will be coming out with the new tail assembly
Old 06-05-2007 | 12:42 PM
The frames are different on the SE V2 from the rest of the new S versions the SA, S-AL and S-CF. The frames on the SE V2 allow a GY401 gyro to be mounted under the tail boom block without any kind of adapter. Also, the SE V2 tail boom block has changed, flat on the bottom...slap on some double sided tape and you are in business, a 401 will mount up without interfeering with the frame sides now!
Kurtzz
