T-Rex heli For all you T-Rex lovers out there, this where you can post!
walkera to t-rex
Old 06-10-2007 | 05:45 AM
Default walkera to t-rex
Hi all
At the moment i am flying or (crashing a lot) walkera 36. I am not really happy with it as it has given me a lot of problems. I am now thinking of getting a T-Rex 450 se, i have a JR X2610 tx which i will use with it. Is this a good combination. What do you think of the T-Rex 600. My other choice is the Walkera 60b but i am now weary of the walkera range.
can some one give me some advice.
Old 06-10-2007 | 11:11 AM
Default RE: walkera to t-rex
well first of all. Why are you crashing so much? If you are crashing because you are still learning to fly then the only thing getting a T-Rex will do is have you crashing a different heli. I have read that some Walkeras can be frustrating to fly but they are still flyable. If your crashes are caused by parts failing upgrade those parts and go from there.
Old 06-10-2007 | 11:30 AM
Hi
I suppose you are right did not look at it that way. The T-Rex just seems to be of better quality. I have replaced most of the parts and electronics. Still strugling with the JR radio setup.
Old 06-10-2007 | 01:17 PM
I transitioned from a Walkera 36 to a Trex. I don't suggest putting any more money in the 36 at all. It's a big transition though, the Walkera 36 is easier to set up on the radio.
HS
Old 06-10-2007 | 01:33 PM
I have put a fair amount of money into the walkera, but i tried to make sure all the electronics are compatible with the T-Rex so at least i am not wasting the spare parts. The setup with the JR radio is not that easy either.
