T-Rex heli For all you T-Rex lovers out there, this where you can post!
gyro issues
Old 06-25-2007 | 08:10 PM
Default gyro issues
got my new se v2 in the air and it rotates to the left slowly. im using a 401 gyro i can correct it with rudder but trimming does nothing.
thanks
ken
Old 06-25-2007 | 08:32 PM
VinceHerman's Avatar
Default RE: gyro issues
There are mechanical issues that will need to be checked, but in my experience, a slow drift has always been vibration getting to the gyro. How do you have the gyro mounted? The foam tape Futaba provides? Do you have any retaining device like Velcro or zip ties touching the gyro? Are the servo leads stuffed between the gyro and the frame? Are the servo leads pulled too tight?
Old 06-25-2007 | 08:44 PM
ill double check ever thing but nothing looks wrong thanks for the advice.
Old 06-26-2007 | 03:42 PM
BarracudaHockey's Avatar
You dont use radio trim on a heading hold gyro.
How did you set it up?
Servo type.
How far out is your linkage on the rudder servo?
What are your rudder atv's set to?
What is the limit pot set to?
Where and how is the gyro mounted?
Old 06-26-2007 | 08:46 PM
i figued it out dummy me didnt have it in heading hold i hade it in regular. after i changed the gain percentages in the radio to heading hold it flew absolutly perfect its so much more stable than my cp pro that its not even comparable. sorry for not relseing what i done.
Old 06-27-2007 | 10:07 PM
My Feedback: (197)
How do I set my radio to heading hold? I have the 9chp and am having this same problem.
Old 06-27-2007 | 10:16 PM
go the opisit way on your percentages for your gain channel. like i was running 50% and it wasnt in heading hold mode so go to -50% or it probably has a A or an N in front of the percent. but just go the opiste way and it should work r u running a 401 gyro
Old 06-27-2007 | 10:21 PM
My Feedback: (197)
I think I am at -50. I am running the 401.
It's like I get it trimmed where it wants to hold and all of a sudden the skids get light and it spins in the opposite direction
Old 06-27-2007 | 10:26 PM
go to positive 50% and make sure when you power up not to move your heli for 3 sec. to check if your in heading hold mode power up the transmitter and heli then move the tail to the right and the servo should move towrad the canopy. then tell me what you find out.
Old 06-27-2007 | 10:28 PM
if it moves toward the tail reverse the servo at the gyro.
Old 06-27-2007 | 10:33 PM
My Feedback: (197)
when I move the nose to the right, the servo linkage moves towards the canopy.
I am set at +50. I was looking at the tutorial on raptortechnique.com
Old 06-27-2007 | 10:41 PM
that is wrong reverse the servo. when you move the tail right or nose left the servo should move toward the canopy. you need to reverse the servo at the gyro. and it should fly alot better.
Old 06-27-2007 | 10:54 PM
My Feedback: (197)
I think I got it. I reversed the tx and gyro.
Old 06-27-2007 | 11:00 PM
just take it easy the gyro will hold if it did what i said it should do. and make sure that when you take off that the rudder isnt reverse of the stick but the only way to know is to fly it and if it is just reverse it in the tx. and you should be ready to go. hope i was of some help.
